Rotel 1066
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by z5461313, Apr 29, 2003.
  1. z5461313
    z5461313
    Sep 18, 2001
    1,630
    +235
    Does any one have this yet and if so, how does it compare to what you owned previously?
    What HiFi says its really good
  2. sounddog
    sounddog
    Dec 11, 2002
    3,437
    107
    Leicestershire, UK
    +477
    Do a search ... I (and several other people) have one, many others have opinions about it from demoing, etc.
    My opinion (running it with a RB985MkII and RMB1075 biamping B&W 602 / LCR60, single amped 601 rears) is that it has a really clear and detailed sound. Its also very good with music ... the equal of a £500 Rotel stereo amp. The best bit is that if ever I decide to upgrade ... I can keep the power amps and just replace the processor.
    Vikki
