RoomEQ help!!!
Moez
I've spent 3 days trying to get my computer hooked up with Room EQ without any success at all. Tried connecting my creative soundcard Live! without any luck. I'm seeing that a manual approach is being offered on both BVD and using the TAMREQ wizard. I guess i'm not the only person having a tough time getting the soundcard connected with the RoomEQ software. I'd rather use the RoomEQ or RS +D which I am licensed than doing it manually. Can you help me get this soundcard of mine acknowledged by RoomEQ?...Thanks.
ralphmalph
Hi if you are trying to use the soundblasters digital connection there are a whole host of known problems with this card. I could not get my sound blaster didtial out to speak to my tag but luckily my computer had a built in soundcard on the motherboard so I used the spdif out socket from that and it worked a treat.
So if your PC has another digital out try and use that.
