Room Size
Discussion in 'Home Cinema Speakers' started by Kev S, Jan 14, 2001.
  1. Kev S
    Kev S
    Im currently running a Denon AVC-10SE with 4 x B&W601's & a REL Q100E sub (speakers set to small). Im looking at upgrading the front speakers (and installing a matching centre speaker).
    I was looking at getting some floorstanders (shortlisted for a demo Yamaha YS200C, Mission MX74 & B&W603..ideally would prefer a magnetically shielded speaker which the B&W is not) but Im worried about the room size which is 12ft x 10ft and whether floorstanding speakers could be too overpowering for the room size (perhaps just upgrade the 601's to 602's ?)
    Any advice re:- speaker & room size would be appreciated.
  2. HT Dude
    HT Dude
    Whatever you do, consider keeping your speakers set to SMALL in your amp setup (even if they are floorstanders).
    As usual, audition at home if you can.
  3. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    You can try it for yourself, but I find that with adequate amp power and as long as the main speakers go down to 40-50 HZ, having the main speakers set to large and LFE directed to both works best. I found that to be the case even with a REL Q200. As for the speakers I can recommend the Celestion C series, the C2 fonts and centre speaker cost about £900. There is a review of them on this site.
    PS They are shielded and my room is 7x14 ft so you shouldn't have a problem.
    [This message has been edited by Jeff (edited 14-01-2001).]
