Room size - wider than it is long?
Discussion in 'Home Cinema Speakers' started by crooked fingers, Dec 11, 2002.
  1. crooked fingers
    crooked fingers
    Dec 11, 2002
    26
    hi all,
    i have a small room for home cinema which makes it hard to put in a couch and armchairs side by side. if i were to put the tv on the long side of the wall is there any disadvantage or has anyone any tips for speaker positioning?
    cheers,
    cf
  2. Flimber
    Flimber
    Sep 22, 2002
    13,719
    Yorkshire
    +4,483
    This used to be the recommended layout for hi-fi speakers and there's certianly nothing 'wrong' with it. Suck and see.
    Mike.
  3. john87
    john87
    If its 'wider than it is long' doesn't this mean the 'wide' bit is actually the long side?
