Room EQ
Discussion in 'Home Cinema Buying & Building' started by starfish11, Mar 11, 2013.
  1. starfish11
    starfish11
    Dec 13, 2012
    473
    46
    +122
    Advice needed on what the best room EQ to use and how to go about it etc all advice greatly appreciated
  2. vinnymcd100
    vinnymcd100
    Jul 8, 2012
    656
    Dunngannon
    +40
    To be able to give advice you'd need to provide some more info..... what amp are you using? does it have any sort of room EQ set up etc
  3. starfish11
    starfish11
    Dec 13, 2012
    473
    46
    +122
    Hi I am using an onkyo 818 and that has set up with mic etc which I have done
  4. logiciel
    logiciel
    Feb 2, 2008
    53,122
    UK
    +5,767
    What information do you need that Audessey didn't give?
  5. goujam
    goujam
    Sep 25, 2010
    2,235
    3
    63
    Brierley Hill
    +187
    The 818 has a pretty good room eq as it is. To improve would mean buying extra equipment which in my opinion is over the top for an 818. What is your issue with your current eq
