Question Room EQ settings for Denon AVR 4306
Discussion in 'AV Receivers & Amplifiers' started by SonicSurfer, Jun 21, 2015.
Tags:
  1. SonicSurfer
    SonicSurfer
    Jun 20, 2015
    2
    Two Rocks Western Australia
    Hi All
    I've owned the Denon AVR 4306 for some years now and have always had the room EQ set to Audyssey for movies and I use the flat EQ curve for multi channel music.
    When set to Audyssey the MultiEQ XT indicator light on the front panel is green. When I switch to Flat in the EQ menu the light turns to red. Does this indicate the flat EQ curve is not active? If so how do I activate the flat EQ curve and the other options in the EQ menu.
    OK ignore above have found the answer. Thanks
  2. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    20,761
    Inbetween Upgrades !
    +10,069
    If you say how you found the resolve it may help others with the same problem.
  3. SonicSurfer
    SonicSurfer
    Jun 20, 2015
    2
    Simple answer as found in the owners manual. The flat and front EQ curves are active and indicated by a red led. I found this a little confusing as red is often associated with no go particularly as when the Audyssey EQ is active the green light is on.
