room dimensions
Discussion in 'Projectors, Screens & Video Processors' started by dan76n, Oct 2, 2003.
  1. dan76n
    dan76n
    May 12, 2003
    88
    australia
    Hi all,
    I am currently building a house and am adding a cinema room to it . my problem is i am unsure what size this room should be.
    currently it is looking a being 2.8 mtrs x 4.4 mtrs but think this may me a little small. any advise?
  2. malcolm
    malcolm
    Jun 25, 2003
    99
    11
    Northampton
    Building a house to have a Home theatre. I like your style !!!
    I guess the basics to consider are how many people would you like it to sit comfortably?
    My converted cellar which i'm currently fitting out is a similar size, but its just myself and the misses mostly! There is squatting room on the floor though if it gets busy!
    I've calculated a 70" image from just over 3m from the HS10 i have on order.
    If you are going the pj route have alook at this site. It should give you rough idea of screen size from some of the best selling Pj's
    http://www.projectorcentral.com/projection-calculator.cfm?part_id=1861&metric=0
    Best of luck with the build.
    Mal
  3. dan76n
    dan76n
    May 12, 2003
    88
    australia
    top site that Mal . thanks
