Flip3seven
I’m in the process of researching and am almost ready to demo and purchase some hi-fi equipment but I am concerned that once I’ve decided which equipment sounds best, the room I intend to install it in, does not have the best acoustics for hi-fi and I could end up wasting my money. The room is approx. 5m wide x 10m long and incorporates an open plan kitchen. The room is a multi-purpose entertainment/games room with TV and a pool table and opens up onto the garden with 5m bi-fold doors. The room is quite modern and minimalistic and doesn’t contain many soft furnishings, other than a corner sofa and therefore has a considerable amount of echo at present.
The floors are laminate with underfloor heating and there is a lot of glass, so loads of reflective surfaces and not very much sound absorbing material. Carpets and curtains are not really in keeping with the décor of the room. I’m hoping some material blinds on the windows and bi-fold doors would help, as would some acoustic panels on the walls but my other half is trying to clip my wings before I turn the space into a fully fledged man cave…...
How could the room acoustics be improved without going overboard? And should I buy a hi-fi based on a showroom demo and try to improve my room acoustics or should I be looking to demo equipment in my room before buying? As always, all help and advice would be appreciated...
