Ronin Region1
Discussion in 'Movie Forum' started by mjn, Jun 6, 2002.
  1. mjn
    mjn
    May 24, 2001
    23,573
    Herts, England
    +11,992
    Does anybody out there have Ronin Region1, and use the Sony 725d DVD player.
    The standard 4:3 version will play no problem, but the on the widescreen version on the flip-side will not. player just shows C13:00, which is, can't read disc.
    I got the disc replaced, the replacement does exactly the same. The disc will work fine in my Pioneer DVD-ROM in my HTPC.
    Anybody got the same problem?
  2. Kev12
    Kev12
    Feb 7, 2002
    4,234
    Leeds
    +453
    I used to have the 725, got the NS900 now, and the widescreen version played fine.
    Maybe youv'e had two faulty discs.
    Not tried it on my 900, better go and see!
    Regards, Kev.
