Roller blind kits
Discussion in 'Projectors, Screens & Video Processors' started by Joshm74, Jul 9, 2005.
  1. Joshm74
    Joshm74
    Aug 12, 2002
    52
    Does anyone know if its possible to buy a roller blind kit that is longer than 240cm? My DIY blackout cloth screen is 270cm wide and I would like to be able to roll it up after use (fixed frame screen is sadly not an option for me :( ).
    I've spent ages searching the Internet and 240cm is the largest kit I have found. The alternative I'm thinking of is to to buy a 240cm kit then simply replace the supplied pole with my own longer pole but I'm not sure if that would work. Anyone have any ideas/suggestions?
    TIA!
    Josh.
  2. Shay Geoghegan
    Shay Geoghegan
    Jul 21, 2005
    Any ready made up kits will only come in very standard sizes which would have a very high demand like a typical Argos product.Do you want the blind to do 2 jobs ie blackout blind and screen?
