For Sale Roland iModela 3D plotter / CNC tool
Discussion in 'Archived Classifieds' started by extremelydodgy, Aug 14, 2013.
  1. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,267
    +68
    I have a Roland iModela for sale.
    The iModela is a small three-axis CNC tool, designed for hobbyist and educational use. You can find details here.
    Unit is in good condition - definite signs of use but no abuse - and is FWO. It's now out of warranty however it did get a clean bill of health from Roland when I sent it in for a build problem a few months ago, and I've only used it for two small parts since then (which completed without issues).
    Apart from what's needed to make it work (USB cable, PSU, software, all original documentation) the unit is supplied with:
    - cutter sheet
    - spare body hooks (+ redundant fan attachment - will not fit supplied drill bit)
    - standard 2mm tip / 3mm shank drill bit
    - spare motor
    - spare grub screws for drill bit attachment + hex driver
    - lube
    - what's left of the original roll of double sided tape
    - cleaning brush
    - 2 sacrificial build beds
    - 2 rotary engraving laminate sheets
    - 1 foam block
    - 2x closed-foam PVC sheets, 3mm & 5mm thick
    The entire thing comes in a travel case. Package is boxed.
    The iModela is suited to making small parts of a very high level of detail - much higher than can be achieved with FDM (Makerbot, etc). You can see the exquisite level of detail possible here.
    There is a learning curve to this thing, as with any 3D printing / machining tech - don't expect to be machining complex shapes straight away. You would probably want to buy a lot more of the foam blocks to get you started in terms of mastering the machining process - they're available from Techsoft UK in the first link above, as are spare parts.
    £350 picked up in London (it's an easy to carry box).
    I have read the trading rules and agree to abide by them at all times until the transaction is concluded to the satisfaction of all parties involved : Yes.
    This message is automatically inserted in all classifieds forum threads.
    By replying to this thread you agree to abide by the trading rules detailed here.
    Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via PM to each other after negotiations are complete and prior to dispatching goods and making payment:
    1) Landline telephone number. Make a call to check out the area code and number are correct too!
    2) Name and address including postcode
    3) Valid e-mail address (no disposable addresses such as @gmail or @yahoo for example).
    DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
    Also we advise that the vendor post images of the items for sale. This helps your sale by showing the condition of the goods prior to dispatch.
  2. splinters69
    splinters69
    Dec 17, 2007
    9,168
    Doncaster
    +694
    Would love this for my school but a. You are in London, im in Yorkshire and b. i cant be sure they would pay me back for it. Was looking at one just the other day.
  3. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,267
    +68
  4. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,267
    +68
    Still for sale.
  5. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,267
    +68
  6. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,267
    +68
  7. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,267
    +68
    Up til Tues.
