Roksan unipivot tonearm
Sue Caddy
Hi, we have the above. We seem to have intermittent problems with the stylus not dropping fully. Any ideas why? Thanks
Ugg10
Is it the arm not dropping or the arm rest not dropping? If it is the former then may be bearings, if the latter then may just need adjusting or new damper oil. Just a couple of guesses to start off the discussion.
Sue Caddy
Sue Caddy
Hi it is the curved black pad ( sorry not technical) that is preventing the arm from dropping fully. It is only a couple of months old. Sure it just needs adjusting but loath to do it myself. It was all set up for us by the vendor.
Ugg10
That is the arm rest and the easiest to fix, the vendor should be able to adjust that easily. A couple of things to check - when you release the arm rest does the arm rest lever slowly go down under its own weight or does it need a little pressure, if the latter can you feel any resistance. Does the arm rest go down slowly or fast, if fast then the damper fluid needs topping up.
Also, not sure what is going on with the anti skate weight, usually the weight is on fishing line / nylon type thread (Edit - looks like the twin is that supplied so OK) and definitely needs to be running over the wire frame in front of it, the position along the graduated bar give you the approx. anti skate setting (less towards the arm, more towards the turntable). The antiskate acts to pull the arm away from the centre of the record.
Hope this helps.
Ugg10
Just looked at your location on your profile and Lintone are not far away. Another memberon here got a Roksan Radius 7 from there recently.
