Answered Robocop Remastered & The Trilogy?
Discussion in 'Blu-ray & DVD discs' started by Evokazz, Oct 17, 2017.
  1. Evokazz
    Evokazz
    Mar 28, 2008
    1,962
    116
    +557
    Hiya guys, was in HMV yesterday and spotted Robocop remastered in 4K on Bluray. I have the Robocop Trilogy does anyone know if the first movie in that is the same 4K remaster or not?
  2. Best Answer:
    Post #6 by -gonzo-, May 14, 2018 (1 points)
  3. -gonzo-
    -gonzo-
    Nov 1, 2009
    10,240
    +6,975
    If its a recent Trilogy set then it should be.
    Check the dates as if your trilogy is dated before the remaster then no it won’t, if its the same or after then it should be.
    The remaster was dated 2013.
  4. -gonzo-
    -gonzo-
    Nov 1, 2009
    10,240
    +6,975
    This one doesn’t
    This one does
  5. Evokazz
    Evokazz
    Mar 28, 2008
    1,962
    116
    +557
    Thanks I own the bottom one so all good.
  6. MarkusThatch
    MarkusThatch
    Dec 20, 2004
    10,024
    3
    +1,964
    Could someone please check the code on the Robocop remastered disc please? Is it WW 15895 BD SE?
    Thanks!
  7. -gonzo-
    -gonzo-
    Nov 1, 2009
    10,240
    +6,975
    Best Answer
  8. hippo99
    hippo99
    Feb 29, 2008
    16,927
    163
    +10,060
    Wasn’t the original disc the theatrical cut only, & the remastered disc the directors cut only, so you can tell that way as well.
