Roberts Stream 93i - PC wizard...
Discussion in 'Music Streamers' started by memyhead, Nov 7, 2017.
Tags:
  1. memyhead
    memyhead
    Feb 25, 2011
    3
    Evening,
    Can someone please help?
    I haven’t used this radio for a good few months but this evening I was listening to it for only about 10 minutes when it suddenly shut down & turned itself back on again only to show the following message
    PC wizard...
    It has been stuck on this for a good half hour and there is no way to get rid of it and use the radio again. Anyone know what this means please?
    Also, is there anyway to do a factory reset, while it is stuck in this mode?
    Thanks in advance.
  2. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,226
    +7,357
    Looks that that's a prompt to connect to a PC via USB to perform a firmware update.
  3. memyhead
    memyhead
    Feb 25, 2011
    3
    Thank you.
    Does the radio come with a lead to connect it to a PC/laptop (it must still be in the box if it does)
    When it's plugged into the PC/laptop do I need to go to a pecific website to download the firmware
    Sorry i'm a tech novice!
  4. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,226
    +7,357
    USB cables are almost never supplied. It will be a standard printer type cable like this that connects to the Service port on the back. But there appears to be no reference to updating this way in the documentation, so you'll have to ask Roberts for advice on how to proceed.
    [email protected]
  5. memyhead
    memyhead
    Feb 25, 2011
    3
    Plugged radio in this evening & it started up so did a factory reset but it just randomly switches off after a few minutes of listening....then re starts but comes up again with the PC wizard message....all very frustrating!
    I’ve emailed Roberts tech support and also Richer Sounds as it’s still in it’s warranty period.
  6. larkone
    larkone
    Apr 21, 2006
    4,358
    134
    North Essex
    +1,229
    If its under warranty then just take it back
