rme volume control with tt2 via xlobby
Discussion in 'Desktop & Laptop Computers Forum' started by Embarker, Jan 3, 2005.
  1. Embarker
    Embarker
    Apr 19, 2004
    1,607
    Garden of England
    +59
    here is my first attempt at basic volume control of my rme card via tt2 with xlobby controlled via a pda
    the button just to the left of film pic jumps to another page which gives the extra dvd controls needed.
    So most of my christmas was spent on a xlobby steep learning curve, but now finally can use the HTPC with out using a mouse or keyboard :clap:
  2. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Sounds like you had more time to play than me then.....
    Glad you've got it sorted, did you use girder or just the xlobby event manager?
    If you could just finish off the dscaler/sky+ that would be great :smashin:
  3. Embarker
    Embarker
    Apr 19, 2004
    1,607
    Garden of England
    +59
    just used xlobby mate.
    i have got xlobby to open dscaler though - it even selects a spare preset volume for RME. Another button exits dscaler and deselects the preset.
    Just need to buy an USBIRT before setting up actual pages which i'll pinch from a colour pronto.
    Finally got rid of the keyboard and mouse - total bliss...........
  4. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Any chance of emailing a copy of your skin folder and then I can have a look at how you've done it?
    I had a play last night and sussed using xlobby's event manager to send commands to my existing gml so I now have dscaler fully working, I just need to do the screens for it.
    Next thing to work out is getting xlobby to repeat the ir commends for sky+ via the usbuirt....
