RME soundcard - do I need the 'PAD' or not ?
Discussion in 'Computer Components' started by Mark Grant, Feb 16, 2003.
  1. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello,
    I am considering upgrading from an M Audio Audiophile 24/96 to an RME soundcard.
    If I only use the digital outputs on the RME will the DIGI96/8 be OK or does the DIGI96/8 PAD have a better quality digital output?
    I realise the analogue outputs of the DIGI96/8 Pad are superb, but my preamp converts inputs to digital anyway (Sony 9000ES), so analogue inputs might be wasted on this.
    Will the RME DIGI96/8 (non PAD) be an improvement with DD and DTS compared to an Audiophile 24/96 soundcard?
    (The non pad version is cheaper, hence the questions.)
    Also, who is the cheapest supplier of RME?
    Thanks,
    Mark.
  2. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    Hi Mark,
    I cant answer your questions directly however I just upgraded to the PAD version and it's quite a significant improvement over the Audiophile card, I got mine from a German site here it now appears to be £200 ish
    HTH
    Steve
  3. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Is going this route a big improvement in using the motherboard digital out? If the RME is taking the source directly from the DVD digital out, is this cleaner than going across the Motherboard?
    Gonna run out of PCI slots at this rate, should have bought a server
    Rgds
    Nathan
