RME Hammerfall HDSP 9632 PCI Card
T
thomasmthering
Does anyone have any comments on this interesting piece of hardware? I am considering it for a pc based recording solution and need some advice on whether to get it or something else. I would prefer to go as best as possible with a pci based recording solution so that I can use it for a long time.
cameronl
hi there, I have the rme9632 (with output boards) & the LynxTWO-B.
I use these only for output purposes though - both for stereo and home cinema. Both are excellant cards but imho the LynxTWO-B is a step up in sound quality for stereo. It is also about twice as much as the RME card.
btw; if you do go the RME route I have an AEB4-I (4 analog inputs board) you can have for cheap ;)
CaM
S
spamboy
As per the other thread about soundcards at the moment, after loads of research I bought one of these for my hi fi system. If you can wait a couple of weeks I'll tell you how it sounds. I believe that it uses the same dac's as the lynx cards, which for the price potentially makes it a bit of a bargain.
Sound on Sound magazine rate the emu products extremely highly for music production (they use the 1818m - which is the multichannel version of this as their reference card), but according to reviews on headfi the sound can be a bit clinical - although extremely accurate.
I've also just got an rme digi 9636 with aeb8-o (which is admittedly the previous generation to the 9632) and m-audio audiophile 2496 in seperate systems so might even get round to doing an comparison.
