RM-MC40ELK/HD 5, no backlight on main unit?
Discussion in 'Headphones, Earphones & Portable Music' started by zenmod, Jun 24, 2005.
  1. zenmod
    zenmod
    When I'm controlling my HD 5 with the RM-MC40ELK remote, the backlight on the unit's display does not turn on.
    In contrast, I remember that with my my previous unit, the HD 3, the backlight on the unit did turn on while using the remote so I'm wondering if this is normal.
  2. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,553
    England, UK.
    +553
    I think it was your NW-HD3 that was "out of whack".
    This is a battery saving feature by not powering the two backlights at the same time.
    When I use my NW-HD1 connected to the remote if I use the buttons on the player the unit's backlight comes on and if I use the buttons on the remote that lights up instead.
    So sounds normal to me.
