Ritek Ridisk burning/not burning?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Knarky, Jul 19, 2004.
  1. Knarky
    Knarky
    Jan 22, 2004
    95
    I recently bought a stack on DVD-R discs from Bigpockets.com which are by all accounts compatible with my burner. For burning I use Nero and Ulead 7.0. Strangely when I attempted a burn with the new discs when using Nero the burner shows as idle and my PC freezes and needs to be rebooted. However when burning from Ulead the discs burn fine. Seems strange to me that the discs would work with one package but not another.
    Nero is working fine with some TDK DVD+R discs I have and has worked with a previous purchase of 04 DVD-R Ritek discs.
    Does any have advice? :lease:
    Knarky
  2. Whitetop
    Whitetop
    Jul 16, 2004
    What make and model burner are you using ?
  3. Knarky
    Knarky
    Jan 22, 2004
    95
    It's a PC BTC 10081M model.
  4. Knarky
    Knarky
    Jan 22, 2004
    95
    Also purchased some -R TDKs but not working either. Have send the drive back and am awaiting a new one. Hopefully the drive itself is faulty as is suggested by tech support, having tried all the possible solutions provided by BTC.
