Ritcher Sounds........Question
Discussion in 'Plasma TVs Forum' started by Fritz, Jun 16, 2005.
  1. Fritz
    Fritz
    i am thinking about getting a plasma and dont have much cash maybe 1000-1100 i am not going to get a hdtv i understand that i will cross that bridge when the time is right all i want is a 42inch plasma that will play my dvds all consoles new and nxt gen and my freeview box so are the plasmas at richer sounds any good like the jvc one looks good but is it a fur coat with no knickers(leave you to work that one out) ;)
    Cheers Fritz
  2. bishman
    bishman
    Mar 29, 2001
    4,904
    83
    hertford
    +174
    Don't forget that to play the next gen consoles to the best of their ability you'll need a hi-def display. If you're not bothered about that, then I'm sure you'll get a good deal for a display at Richer sounds.
  3. Bacus
    Bacus
    Dec 30, 2004
    8,586
    Close to the sea
    +2,707
