Risk of harm to amp?
Discussion in 'Subwoofers' started by Arif, Sep 18, 2005.
  1. Arif
    Arif
    Feb 13, 2004
    94
    Northampton
    Hi all,
    I've got a Yahama DSPAX757SE connected to an SVS 25-31 PC+ (which ROCKS, by the way!! :) ).
    As with many set-ups - one has the option of simply turning the sub off at its own switch - for example when the Mrs is watching normal TV, type thing ("Too boomy!"). And before anyone covers this point - I am happy with how it's been calibrated; Crossover is at 80Hz, and gain is just right for when you want it (movie) - and the sub does essentially 'disappear' for most of the time, and only kick in or become noticed once something happens below 80Hz - but even a door slamming then on TV, constitutes 'too much bass'!!
    So - rather than setting the risky precedent of allowing her to fiddle with any of the knobs on the SVS' amp-plate (plus access to and visibility of this is restricted) - I find it much easier to show her where the sub's main switch is. And nor do I want to go down the route of telling the amp that there's no sub attached - cos that's not really convenient.
    However - I seem to recall from long ago - that when an amplifier circuit is outputting a signal - one MUST ensure that there is a 'load' at the other end. A signal output to a free-ended cable will harm the amp/transistors.
    1) Is this true?
    2) Would it be true of the tiny 'pre-out' signal - as is the case for the subwoofer (4volts)?
    3) Is it possible that the sub itself will 'manage' the end of the cable, even when the unit is switched off, in such a way as to keep it 'loaded'? (Although I know that Erik at SVS would technically be the best person to find this last point out from)
    Bit of a funny query - but I hope that you get the gist!!
    Thanks in advance people,
    Arif
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The load will be there, switched on or not, but it doesn't matter anyway. Transistor circuits in the main don't mind no-load, but don't like overloads or shorts. I switch off the woofer all the time on my Yamaha RXV-1500 (and previously on the RX-V640RDS) with no problems at all.
  3. Arif
    Arif
    Feb 13, 2004
    94
    Northampton
    Excellent!
    Thanks Nick.
