ripples apeared in tab tentioned screen?
Discussion in 'Projectors, Screens & Video Processors' started by gazor, Apr 25, 2007.
  1. gazor
    gazor
    Apr 6, 2007
    10
    4
    bury lancs
    my 6ft electic tab-tentioned screen has ripples apearing on top left an right of the screen.it is over a radiator, which is now permanenly off.
    will the ripples dissapear over time now or is it ireversable?
    is there anything i can do
    thanks all
    gaz
  2. rich2000
    rich2000
    Nov 20, 2006
    125
    +6
    Sorry this may be a stupid question but, have you tried loosening the tension strings on that side?
    If it is cause the screen has streched more on that side you could wedge a bit of card in material roll to help balance it, not ideal i know.
  3. gazor
    gazor
    Apr 6, 2007
    10
    4
    bury lancs
    [if i loosen it it would be worse mate,it flattens perfectly if i just pull the top tabs. im sure its just the heat from the rad that has caused the ripples.im hoping that now its cold it may contract, heres hopin
  4. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    maybe daft answer but why not ad some weight to bottom left corner at the back of the screen. like those weights you put in your boxing gloves
  5. rich2000
    rich2000
    Nov 20, 2006
    125
    +6
    A corse way of dealing with ripples at the side of the screen is to insert a piece of card between the wound material thus rasing the screen material on that side.
    Rich
    HCSV
  6. carlknichel
    carlknichel
    Try leaving the screen in the down position for a few days to let the screen material get used to the room temperature. Also try tensioning the screen on the bar, unitl the nylon is tought, leave it for a few days and make some more adjustments. that should help
