Ripping with EAC to FLAC, tagging problem
Discussion in 'Headphones, Earphones & Portable Music' started by Pgmabley, Feb 8, 2009.
  1. Pgmabley
    Pgmabley
    Feb 29, 2008
    304
    Westcott, Bucks
    +28
    Read through all the advice and stickies on this, but can't find a direct answer to my problem.
    I decided to rip all my cd's to FLAC on an external hard drive.
    I can get them all onto the hard drive, but I have to set up folders for each album (not a problem) with the album name. No tagged info comes over giving track names etc, it just labels them track 01, track 02 etc etc...
    I downloaded mp3tag and tried to get them to label them after that with no success, but I admit I don't really know how to use the programme.
    I don't really want to individually type all the track names out myself.
    I assume I'm doing something wrong along the line somewhere, any advice out there?
    Paul
  2. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    So you need to read the stickies again :)
    Sounds like (at least) these setting are wrong -
    EAC Options->Filename->Naming Scheme (N.b I use '%C\%N - %T')
    and Compression Options->External Compression->Additional command line options (N.B. I use '--best -V -T "artist=%a" -T "title=%t" -T "album=%g" -T "tracknumber=%n" -T "genre=%m" %s')
  3. Pgmabley
    Pgmabley
    Feb 29, 2008
    304
    Westcott, Bucks
    +28
    You are quite correct, some more in-depth reading was required. It is difficult reading and understanding all the info out there, you just need to get started and make the mistakes for yourself unfortunately.
    I found this information within the stickies for anyone else requiring a EAC setup guide. It's for an older version but you get the required info.
    See Here
    Paul
