Ripping mix albums
Discussion in 'Desktop & Laptop Computers Forum' started by Molly, Oct 18, 2003.
  1. Molly
    Molly
    Jun 15, 2001
    212
    Lincolnshire
    I've started ripping my cd collection onto my HCPC using EAC into Monkey compression. I have tried both Xlobby and 4am as a front end using Winamp as the player in the background so I can use the ASIO plugin for the Revo.
    How can I rip mix / live cd's and keep the tag data but not have a gap between tracks.
    Do I rip seperate tracks as normal and change the settings in winamp?
    Do I rip as one large wav and split the file with additional software?
  2. Fe+
    Fe+
    Apr 29, 2003
    281
    Cheshire
    +5
    i used to use sound forge to rejoin the files back up, or as you say rip as one large file
    have used hjsplit before as well this will rejoin after splitting
  3. diesel_uk
    diesel_uk
    use the new easy cd creator it has a rip into segments thing i used to use soundforge too untill i use3d the eacy cd 6 app
