RIO Karma - still available?
Discussion in 'Headphones, Earphones & Portable Music' started by pancake, Sep 17, 2005.
  1. pancake
    pancake
    Jan 29, 2005
    7
    Appreciate the issue of RIO going under & the availability of the Karma has been discussed on a couple of existing threads, but these seem to have gone quiet recently.
    Has anyone found the Karma still available anywhere? Dukebox.com (via Amazon) has dried up.
    If not, what suggestions for a substitute. Size isn't an issue(!) - this is going to be used in the car, so the important things are sound quality & battery life.
    Thanks.
  2. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    I've got the Iriver IHP140.
    Excelent battery life, and good line out quality.
    Not too big either, But really big if comparing to the wafer thin, jobbies....
    Good solid machine, with 2 years warrenty I believe!
    Customer service is all handled from somewhere in europe, but I'm told that when you send it too them , they are very good and repairs and return...
    No need for that with mine (14 months old).
    I use mine on my motorbike, so you can be sure that it can take some abuse!
    Gareth.
  3. shezzy2k
    shezzy2k
    Aug 17, 2004
    492
    28
    +26
  4. pancake
    pancake
    Jan 29, 2005
    7
    Shezzy2k - thanks for the tip, not sure about a refurb though. Anyone else gone down the pre-owned route?
    Gareth - not thought about the iriver - I'll check it out.....
  5. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,465
    +6,239
    go on any price comparison site, to see all the bargains all across the Rio line ;)
  6. myepitome
    myepitome
  7. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    Also, to my suprise, the IHP140 has reduced in price by £15 in a year!
    How many electronic items of this nature can you say this about?
    Well worth it, and has Optical interface aswell...
    Gareth.
  8. pancake
    pancake
    Jan 29, 2005
    7
    Finally got a Karma from Comp-U-Plus.com in the states! Made an absolute schoolboy error though as obviously when the package arrived it contained a 2-pin charger - DOH!!!
