Ring Video Doorbell Review & Comments
ODB_69
Have had one of these for around a year now along with the chime so few bits of info
Charge lasts ages but is dependent on what your preferences are, adding motion puts more pressure on the battery life so on average with us having motion set to standard but on full range we charge every 2/3 months. You'll easily burn through in a month if you have live view on, however really should only use this if you have it wired
Extremely sensitive to Wi-Fi changes so every now and then it will drop out altogether despite everything else Wi-Fi working fine. Can be a pain and device health will show as fine still annoyingly
Every now and again it goes a bit loopy, sends you false motion notifications (but doesnt record any video), starts delaying button presses or motion, ring button goes into a cycle and it's ringing for a few minutes
Also my first units motion sensors packed up altogether after 8 months so had to have it replaced.
Can't fault the warranty, even covering you if the unit itself gets stolen
For me it's not perfect, however I would say in a few revisions time it should be far far better
chrisstu
There are a few weaknesses in the review IMHO. Given the various complaints online about delays between pressing and receiving notifications, this should be addressed. And no mention of the need for the device to make an internet connection to Rings servers. In theory this could use the local wifi network for notifications, avoiding internet issues and making it more reliable. Personally I just installed a wired video entryphone with no need for internet, simply because I want reliability over everything else.
Greg Hook
Moderator & Reviewer
I can only review how it worked for me. Not what issues others have had. I had no delays or issues, so can only review how I experience it. I obviously kept an eye on the main thread for this device and can see a few issues experienced by people, but on my side I had none.
How easy would it be to nick the doorbell or knacker it?
It's screwed to the back plate with two security screws. So can't be easily removed. But can of course be knackered and removed with brute force if needs be although I obviously didn't do a destructive test on it! But as mentioned in my review if it is stolen Ring will give you a new one for free when you provide them a police report.
missgee
I installed the ring pro a couple of weeks ago; like the OBD_69 said it is "extremely sensitive to Wi-Fi changes so every now and then it will drop out altogether despite everything else Wi-Fi working fine".
The most annoying thing for me is how quiet the chime plug is, you'd be lucky to hear it over a TV, and I can only hear it in the room its plugged in, I'm not even sure one per floor would do it.
With regards to installation;
I originally had a push doorbell running to a battery powered chime unit, and this had to go- the basic ring doorbell can be wireless, but ring pro needs a wired push AND, what they don't spell out, it then also needs a wired connection to mains power. They supply a transformer in the box and say you could wire this into your existing chime unit if it already has a mains connection, but what we did was wire the push button to the transformer and just put a bit of flex and plug on the transfomer, which works fine. HOWEVER it means I lost the original doorbell chime box, and their plug in unit is appalling.
ODB_69
Free replacement if stolen under warranty, not sure about if damaged
So unit itself slides on to a plate, 2 small screws at the bottom hold it to the plate. Fits fairly snug so difficult to remove unless they have a set of small star screwdrivers. The plate itself anchored to the wall so only getting that off with some serious force from a hammer or crowbar which would probably destroy the unit itself in the process
I've taken the risk of using heavy duty Velcro though to attach to my UPVC door which works nicely without causing damage
Something else the review misses, though novelty, the doorbell chimes. You get seasonal one as well. I chose the Santa Ho Ho Ho at Christmas for instance. Admittedly the volume got turned down on that after a while
Greg Hook
The most annoying thing for me is how quiet the chime plug is, you'd be lucky to hear it over a TV, and I can only hear it in teh room its plugged in, I'm not even sure one per floor would do it.
Surprised at that, not sure if you have a dud as the chime I was sent was very loud. I had to turn it down actually.
I did mention the doorbell chimes, especially the dogs barking. :)
ODB_69
Yeah I spotted that, just seasonal tones only appear during seasonal times. Around Thanksgiving there was a turkey gobble tone and there was a load of different ones at Christmas lol
Jeek
Agree with the comments so far. I'm also a long term user. When it works well it works well, but agreed its very sensitive to WiFi fluctuations or internet bandwidth performance. I have a powerful wifi router and high speed broadband but ended up buying a powerline wifi extender and put it as close as possible to the Ring. Since then I rarely have any issues. Before that I'd quite often get stalled video or even not be able to connect.
I don't have any issues with battery life. It last a good month or two for me even with live view enabled. I do have the range sensitivity turned down quite low however as otherwise people and cars passing the drive would trigger it, rather than only people on the drive.
One of the main issues I see is the time taken to start uploading video when movement is triggered. Rather than immediately record, buffer and start uploading once its connected to the wifi, it appears to only record once connected to the wifi (it sleeps until the IR camera is triggered). So quite often you can miss the initial few seconds of movement. I had a youngster playing knock doors for a week on the house (obviously as he loved the chime noise it makes) and I always only caught the back of his head as he ran away! Having said that since Live View mode was introduced and I got the wifi extender this aspect is a bit better.
Superaintit
Something I don't understand is...why would a burglar go for the front door?
Isn't it obvious he or she would choose the easiest way in and would rather choose a backdoor or a window than the front door?
shango
I'm sure the police will be rushing round to your house to file a report when you ring them up and tell them your door bell has been stolen :D
ODB_69
Lol I have thought this as Well, despite owning one
The good thing is you get to see the video of them stealing it at least
Greg Hook
Often they ring the doorbell first to double check no one is in. Clearly they wouldn't break in from the front door but it's a good place to confirm the house is empty.
As I'm sure you're aware you don't need the police to attend to get a report for insurance purposes.
MikeTheBike2010
Looks like an interesting gadget, did I not see this on Click recently in their hall of shame of devices which were insecure WiFi wise (allowed anyone with the nous access?).
Stuart Wright
AVForums Founder
Staff member
@Greg Hook are you doing a long term test of the doorbell? Because if so, then you can update the review with any issues should they arise.
In the mean time, we as a review site can scrutinise products more in the areas where there are known issues, but we can only report on what we find. As an independent review organisation our most importent asset is our impartiality and transparency and the reputation we have in that regard. So if we have the opportunity to report on any issues we find during long term tests, we will do whenever it's possible.
Greg Hook
Yes, it is a long term test. So if issues do develop and remain I will of course update the review.
Paul7777x
I don't know why at all... but I want want of these. And nobody ever knocks on my door. :)
Jeek
One of the most common forms of burglary is an opportunist thief that simply tries a few front or back doors until they find one that's been left unlocked. If you think about it it makes perfect sense - you don't look suspicious if you open a front door and walk in vs climbing in through a window.
A local resident that had a ring doorbell recently posted a video on Facebook of someone trying their front door in the middle of the night.
If you follow Ring on Facebook, their feed is practically full of videos of:
  • Someone checking the front door to see if they can get in, and they can't.
  • Someone checking the front door to see if they can get in, and they can but they've now been caught on video.
  • Someone checking the front door to see if they can get in, and the home owner shouts at them with Ring and they run away.
  • People stealing parcels left on the front porch (very prevalent in the US it seems).
Personally and luckily I've had no one suspicious do anything since I got it (except the odd knock door run). Meanwhile I've been able to use it to talk to parcel delivery people to tell them where to leave the parcel or to take it back with them. Also used it to ignore the odd salesman or someone "sharing their good news".
raduv1
Can't see the point of this TBH , really can't see the benefit for us in our home.
shango
yes but judging from many reviews and samples of quality i've seen you'd be telling the police "he looked like that bloke from minecraft"
ODB_69
Well it's certainly not at the level the tv adverts show however it's not as bad as some of the things I have seen. It's quite viewable tbh but yeah a better camera would be nice
Latest News
Sonus faber unveils new flagship Arena speaker series
  • By Ian Collen
  • Published
Sharp showcases its upcoming 4K TV and audio line-up
  • By Ian Collen
  • Published
HiFi Rose announces all-in-one RS520 audio streamer
  • By Ian Collen
  • Published
LG Display set to launch its own 27 and 32-inch OLED panels in 2023?
  • By Ian Collen
  • Published
What's new on Netflix (UK) for October 2022
  • By Ian Collen
  • Published
