Ring Tone Themes
stevos
I had 3 'themes' on my n95 which i used regularly.
Theme 1 = normal ring tone for home and out and about
Theme 2 = vibrating for use on the train
Theme 3 = single beep for use in the office.
Is there anyway to do this with the iphone?
bransoj
Think on the iphone you can have it so its noisy, with the option of different ring tones for different people, or flick the switch on the side for silent with vibrate turned on or off.
Suspect there may be something if you jailbreak but dont know for certain as i havent jailbroken mine.
williamus
With non-jailbroken phone, I think the way you'd have to do this is:
1. Vibrate only - no problem
2. Normal ring tone - no problem
3. Single bleep - create a ringtone of a single bleep (e.g. with iRinger) and then select that as the default ringtone when you're at work. You'd have to turn off the message/voicemail alerts too, otherwise you'd get that annoying horn going off. If you've allocated ringtones to other contacts then it won't work either... a tad fiddly, but I think it would work.
Desmo
If jailbroken, you can use Auto-Silent. It allows timed profiles with different setting for each. You can also manually select a profile if you want to.
