Question Ring Flash for Sony A6000
Discussion in 'Photography Forums' started by topgazza, Jun 21, 2015.
  1. topgazza
    topgazza
    Sep 3, 2006
    14,432
    Near Basingstoke
    +3,583
    Getting lots of conflicting websites on flash units for the Sony A6000. Looking for a ring flash that will fit on my Sigma 105mm Macro(Canon fit) that I use with an adaptor on my A6000. Not looking at wireless external flash but a dedicated ring flash.
    Happy to consider most price ranges but something around £0-£150 but not cheap rubbish. One of the issues is that a flash with a Sony/Minolta shoe wont work on the A6000. Cant seem to find out why.
    I have found a fix for non firing of flashes which involves sanding some clean metal in the camera hot shoe to create a ground so I'm happy with that aspect.
    Its just which ring flash will work on my A6000
  2. twist
    twist
    Nov 19, 2006
    16,364
    +5,013
  3. topgazza
    topgazza
    Sep 3, 2006
    14,432
    Near Basingstoke
    +3,583
    I'll check those out thanks twist. I assume hotshoe should be OK.
    Its annoying that I can't find a simple statement about what type the A6000 hotshoe is and if its truly "Universal" as in any make flash will work....
  4. shotokan101
    shotokan101
    Jun 16, 2009
    75,879
    33
    Glasgow
    +25,832
    any low voltage ISO shoe "should" fire the flash but only the sony specific MIS compatible ones will work in TTL mode I think
  5. topgazza
    topgazza
    Sep 3, 2006
    14,432
    Near Basingstoke
    +3,583
    There are a few of those I think. Meike and Yonguo do one, I think... its finding the right one of course
  6. topgazza
    topgazza
    Sep 3, 2006
    14,432
    Near Basingstoke
    +3,583
    From what I can see the Meike looks OK to try at only £22. I would leave it on constant light and just select correct exposure etc in the camera
  7. shotokan101
    shotokan101
    Jun 16, 2009
    75,879
    33
    Glasgow
    +25,832
    Isn't that an LED light "that you can make flash" as opposed to a ring flash? - not normally anything like powerfull enough to use small apertures....
  8. topgazza
    topgazza
    Sep 3, 2006
    14,432
    Near Basingstoke
    +3,583
    It is... want to try a bright light on the subject... as in LED... rather than a specialised flash. If I like it and I can find a better quality one for the A6000 I would invest in a proper ring flash. But I like the idea of something that lights up the subject without a flash and see what I get
  9. shotokan101
    shotokan101
    Jun 16, 2009
    75,879
    33
    Glasgow
    +25,832
    GLWT :devil:
  10. topgazza
    topgazza
    Sep 3, 2006
    14,432
    Near Basingstoke
    +3,583
    If there was a wider choice I'd go for it now. Just don't fancy spending £200-350 on a ring flash from Metz or Sigma..... not just yet anyway
  11. shotokan101
    shotokan101
    Jun 16, 2009
    75,879
    33
    Glasgow
    +25,832
    I know the feeling :(
  12. topgazza
    topgazza
    Sep 3, 2006
    14,432
    Near Basingstoke
    +3,583
    I mean... I would as I'm sure having a quality ring flash would help with my macro pictures even though I haven't really needed one so far. But it would be nice to stop down as far as possible to get the detail without losing anything.....
  13. shotokan101
    shotokan101
    Jun 16, 2009
    75,879
    33
    Glasgow
    +25,832
    as you so recently said @twist - I mean @topgazza ..... "it's only money...." :devil: :D
  14. topgazza
    topgazza
    Sep 3, 2006
    14,432
    Near Basingstoke
    +3,583
    This is true......
