radeohedca
Hi there.
I'm considering the purchase of a "Ring Wired" doorbell along with the Chime Pro 2.
I understand that the Ring Wired doorbell will not work with your existing old chime so you need to buy the Ring Chime which plugs into an A/C outlet.
My dilemma is that now I have a hole in the wall with wires hanging out from where the old chime used to be. Sure, I could just leave the old chime in place but I don't really want to. I also don't want to have to shove the wires into the hole and plaster over it, then paint that section of wall. What I WOULD like is to put the Ring Chime on the wall where the old chime was but of course there's no A/C outlet there, just the transformer and doorbell wires.
The only way I can see doing this is to get inside the Ring Chime and bypass the internal A/C transformer then connect the doorbell transformer wires (already stepped down A/C) to the rectifier which will come out the other end as DC, which is what the Ring Chime electronics would be running off.
Has anyone done anything like this or does anyone know where I might get a schematic for the Ring Chime Pro 2 ?
Thanks.
Thanks.
