Matt_C
Okay, odd one this, can't figure it out...
Couple years ago got my mum two freeview boxes for the two TV's she has. Aerial on roof, one cable comes down side of house, and goes through hole in wall to a TV point. On this is a twin output diplexer thingy. One cox runs to one TV, one runs to TV in other room (both run under floorboards)
So, when we got them they worked fine, virtually no probs, everything cool.
Lately, she's been having problems specifically in the "other" room (other being the room where there is no direct RF output, cable runs from diplexer wall plate in "room 1" under floorboards directly into back of FV box). This I could solve by swapping cables over from output A (other room) to output B (room 1), but of course this meant that output B wasn't providing signal to tv in room 1, so not a great fix. Sometimes I swapped em both over (now output A is feeding tv in room 1, and output B is feeding TV in other room) This would work for a while, end up swapping back again.....
Anyway, decided first thing to do was replace the diplexer. Got new one, removed old one, fitted new one, worked fine. Happy days.
Now it is back to it's old tricks!!!
The problem is that FV reception on other room keeps losing signal, very eratic, but only with specific mux's (whatever mux ITV2 is on) and signal jumps constantly from low to high, meaning a breaking up and very blocky picture.
Now, I made a discovery this eve on a fleeting visit : output A is feeding FV in other room, output B is feeding FV in room 1. If I unplug output B, FV in other room instantly becomes perfect - even tho I haven't touched that cable! Soon as I plug output B back in, reception in other room goes pants again. Doing the opposite has no effect on reception in room 1, as this is either perfect, when plugged in, or non-existent, when unplugged.
I don't get it? I don't understand how the diplexer would be giving some sort of intereference(sp) between the two? I realise it's not isolated as both outputs share a common input, but for this to happen with two dixplexers?
Perplexed, I am!
Would I be better trying a) yet another diplexer or b) fitting an external RF splitter (like this : PICCY LINKY) outside and feeding two coax's into the house, to an isolated twin output wall plate?
Any idea's?
Perplexed, I am!
Any idea's?
