Right old whinge!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Nick Laslett, May 21, 2003.
  1. Nick Laslett
    Nick Laslett
    Oct 9, 2002
    Why are there no decent PAL progressive DVD players on the market?
    If it's NTSC region 1 you want. There is loads of choice, just look at the Secrets Progressive Scan shootout, it's in it's third year now.
    From what I can see, there are only 2 DVDs that are PAL progressive off the self.
    Arcam FMJ-27 £1300
    Arcam DiVA 88+/89 £800
    There are a couple of others that can be PAL prog enabled!?
    Philips 963SA
    Nad T562
    Harmen Karden DVD25
    Denon 2900
    But nothing seems to quite fit the bill.
    I want a DVD player that is free of the Chroma Bug.
    I want a DVD player that has selectable audio delay
    I want a DVD player that can squeeze 4:3 material because my silly old plasma can't display 4:3 in progressive mode!!!!!
    None of the above quite fits the bill. I would buy an iScan Ultra but that doesn't except an input of RGB signals!!!
    When are the electronics companies going to get their act together?
    I liked the look of the Denon 2900, but the Secrets review on the Denon 3800 poured water on the way the Denon handles Chroma upsampling, said it was not a very good solution!
    I've got 42" Plasma panel and I just want to feed it a decent DVD signal. I've got £1000, I'm waiting to spend. Why, oh, why can't I find a product to suit my requirements? Is it too much to ask?
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,217
    UK.
    +2,758
