Right I've finally decided! Kind of?
Discussion in 'Plasma TVs Forum' started by lami, Sep 21, 2005.
  1. lami
    lami
    Right people I think I've finally decided to buy a panny! :thumbsup: However my problem now is which model do I buy? I have £1500 any suggestions? I'd obviously like it to have a good picture and if possible HD ready! Go on! give me your point of view! I know that theres a lot of panny lovers out there!
  2. tjradiohead
    tjradiohead
    Jul 29, 2005
    4,036
    71
    +58
    £1500?
    Pannasonic?
    no chance.
  3. simon33
    simon33
    Take a look at the Panasonic PW8.
  4. andye2004
    andye2004
    Sep 11, 2004
    720
    28
    +31
    Do you want a TV or a panel?
    If you want a TV you could get the pe50 - not HDTV though, you could get a 37" PV500 that is HDTV for just over £1700 from Curey's online see http://www.currys.co.uk/product.php?sku=455533&camp_id=kelkoo.
    If you want a panel have you already got something you can get the sound through? If not you will most probably be looking at the PW7 unless you up your budget a bit. Of course the PW8 is an option at your buydget but you would still need to add sound.
    If you wait a little while longer I'm sure one of the forum experts will be able to advise you better though!
