Right Click on Mighty Mouse
Discussion in 'Apple Forum' started by vr360homes, Sep 5, 2007.
  1. vr360homes
    vr360homes
    I know this may sound stupid but I am new to mac's. I have just got my new imac with the wireless mouse but can't work out how to right click or if this is even possible?
    If not I will have to use another mouse as I can't go without right click.
    Lee
  2. Southernguy
    Southernguy
    Nov 26, 2005
    361
    Hampshire
    +19
    I did this the other day. Go into system preferences, keyboard and mouse and then on the mouse tab.
  3. jont
    jont
    Apr 8, 2002
    4,335
    near Aylesbury
    +577
    Goto system preferences>keyboard&mouse>mouse and set the right button to secondary !!
    Jon
  4. Southernguy
    Southernguy
    Nov 26, 2005
    361
    Hampshire
    +19
    I've spent way too much time playing over the last week that i've had my imac!!!
  5. barongreenback
    barongreenback
    Mar 30, 2005
    980
    +59
    It's not the easiest thing to use though, depending on how you hold your mouse. I'd prefer something apple designed with a bit more feel to it.
  6. richard plumb
    richard plumb
    Jan 27, 2002
    14,524
    Windsor
    +1,054
    agreed. Not as sure when I click it that it won't just register as a normal click.
    In half a mind to use my MX revolution, but not a fan of wasting another USB slot
  7. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    42,875
    11
    13
    167
    ::1/128
    +16,289
    Key is when you right click to not have any other finger resting on the mouse I noticed....That's the bit to get used to I found, but once mastered it is very good...
  8. pixelated
    pixelated
    Feb 12, 2005
    1,847
    +94
    I agree - the Mighty Mouse with a bit of patience is really nice.
  9. vr360homes
    vr360homes
    Thanks for your help, it's a bit tricky as I am left handed but I'm sure it won't take long to get used to.
    Lee
  10. Deleted member 92943
    Rather than starting a new thread i'll ask my question here.
    Im currently using the wired might mouse that came with my mac. The problem is that the scroll ball is crap and i have problems using it. I can scroll up but it won't scroll down as it always seems to be a bit stuck.
    Any ideas on how to solve it
  11. barongreenback
    barongreenback
    Mar 30, 2005
    980
    +59
    It's probably just got dirty. You can roll the ball around on an alcohol wipe or something similar. I find that usually a firm circular movement on a clean cloth seems to work. The mice are notorious for this - as soon as I can find a better bluetooth alternative that matches the imac, I'm buying it.
  12. jont
    jont
    Apr 8, 2002
    4,335
    near Aylesbury
    +577
    Have a search through the threads - there were some cleaning tips recently ...
    Jon
  13. spooney
    spooney
    Oct 2, 2006
    2,252
    Seyring
    +204
    Yepp, there was a whole thread on this topic with tips like washing in a solution and letting it try while using a spare mouse (not sure, if this was serious) and a lot of other tips.
  14. Deleted member 92943
    sorted:D
  15. spooney
    spooney
    Oct 2, 2006
    2,252
    Seyring
    +204
  16. theronster
    theronster
    Nov 1, 2004
    81
    11
    +3
    There are some problems with right clicking on the wireless Mighty Mouse - something seems to happen with the bluetooth settings after a short while and the right clicking stops working.
    Turning the mouse off and on again (any I.T. Crowd fans) seems to reset the connection and the button works again.
