Right Channel Broken
Discussion in 'AV Receivers & Amplifiers' started by sampie, Mar 27, 2006.
  1. sampie
    sampie
    Hello I would really appreciate some advice,
    I have an old Cambridge A5 for which the right channel doesn't work (after turning it on without wiring the right speaker). All I get through the right channel is a hum and the occasional crackle/pop.
    Is this at all/cheaply repairable?
    Thank you!
    Sam
  2. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    Some early amplifiers didn't have any kind of protection circuits. If they were switched on without a load (speaker), the output stage would self-destruct. My very first amplifier - an Amstrad 8000, over 30 years ago - did that, and it was a dustbin job.
    It's most likely a blown output transistor, possibly both if it uses two devices per channel. Hopefully, they should still be available from somewhere like RS Components. A simple job to change them, and cheap if you do it yourself.
    The transistors should have numbers printed on the top of the cans.
  3. sampie
    sampie
    Thanks alot for you advice,
    I took the lid off and I can see that 2 resistors are melted/charred, nothing more though. I might pop into a local electronics shop and ask, cheers.
    Sam
