Right Angles Banana Plugs
Discussion in 'Cables & Switches' started by Rob_Quads, Aug 29, 2005.
  1. Rob_Quads
    Rob_Quads
    Feb 14, 2004
    375
    Chandlers Ford
    +11
    Anyone know of any suppliers of right angle banana plugs - would make my living room setup soo much neater as all the cable from the wall sockets either go up or down so with normal plugs loop out a bit at the mo = untidy
  2. loadsofleads
    loadsofleads
    Hi, Supra manufacture banana plugs which can be used either on axis or on a 90 Degree angle, should do what you need :thumbsup:
  3. Rob_Quads
    Rob_Quads
    Feb 14, 2004
    375
    Chandlers Ford
    +11
    Thanks but I think £100 is just a bit much to spend (straight ones were only £18 for 16, other areas of the rooms would benfit first over the banana plugs
  4. pwood
    pwood
    Dec 6, 2003
    2,565
    Central Scotland
    +160
    Just use bare wire straight to binding post. Sound quality will not suffer over short tem however oxidisation will occur over time which will require stiping cable back or use of a dedicated cleaner sure as Caig-DeOx it
  5. Rob_Quads
    Rob_Quads
    Feb 14, 2004
    375
    Chandlers Ford
    +11
    There are no binding posts only banana sockets
