Right angle adaptors
Discussion in 'Cables & Switches' started by treecreeper, Jun 4, 2005.
  1. treecreeper
    treecreeper
    This question was attached to a screens question in the screens forum...it didn't get an answer so I'm putting it in the right place...
    I have a Screenplay 4805 projecting onto a wall, but imminently onto a drh Slimline screen. To fit the image neatly onto the screen I will probably need to move the projector back a few inches....but there's a window in the way. A possible solution is to have the component cables entering sideways on instead of sticking out directly backwards. Is there such a thing as a right angled phono adaptor? Maplins have a phono plug with a wire lead at 90 degrees. I could solder something together based on this but it would hardly do justice to my Mark Grant cables. I need something high quality with a phono plug and socket set solidly at a right angle.
  2. John
    John
    Dec 13, 2002
    11,264
    +2,881
    Some thing like this perhaps ?
    JS
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
  4. John
    John
    Dec 13, 2002
    11,264
    +2,881
  5. treecreeper
    treecreeper
    Problem solved....thanks Johnscarlet and eviljohn2
