Thug
I couldn't get those past the wife, they are larger than my cinema room speakers unfortunately.
or one of the pimax models.
Not sure the OP's 1070 would support a new generation Pimax. Even @Atmos hasn't recommended one in this case.
Believe me, she hates the rift sensors on the wall so the lighthouses would take some persuading.Good job she doesn’t have problems with printers
What speakers do you have they must have less than a 3cm driver?
The lighthouses are quarter the size of a Blu-ray case.
What's that printer plugged into then?My USB cables are pushed under the skirting board so you cant see them.
Much better than a multi-gang plug extension hanging out of the wall at the power socket and a power lead going to the lighthouse.
Another USB cable which is also hid and the single socket behind the cabinet.What's that printer plugged into then?
It's fairly easy to hide a plug adapter behind a cabinet or bookshelves. It's a lot harder having to run USB everywhere and praying to the cabling gods that it actually works.
Ok well ordered the Vive which should be here tomorrow and a mate (lives 200 ish miles away) has sent me a 3rd light box/plug/bracket and a spare vive controller he doesnt have time for anymore....for FREE!
Will set up later in the week if not weekend and get some games downloaded.
100% getting Beat Sabre,Job simulator and a few others
Nice one.
Download advanced settings and crank the Super Sampling to 1.4 on your 1070.
Get The Blue it’s a must have first experience imo.
You only need the two in opposite corners for complete coverage of a rectangular area. They have a significantly wider sweep (120x120 degrees) than the Oculus cameras.Ive just read the vive only supports 2 base stations and a 3rd wont do anything or may cause interference???
Shall I just use the 2 in opposite corners of the room as advertised??
