Ridiculous Sky+ installation situation - please help
Discussion in 'Sky Digital TV Forum' started by Matt V, Aug 27, 2004.
  1. Matt V
    Matt V
    Aug 16, 2004
    69
    11
    +5
    Hello there.
    I've just come off the phone to Sky sales, fully intending to buy Sky+ there and then, but didn't. Here's why:
    My flat has a communal dish. And as it is a new build, I am lucky enough to have two satellite points pre-installed in the living room. At this point in the conversation, I was referred to an independent supplier - usual procedure I assumed.
    I rang the supplier, who offered to install the box for £60, which seemed reasonable, but advised that the box itself would cost £199. When I pointed out that this was £100 more than the deal advertised on Sky's website, I was told that they couldn't match that deal but that I should call Sky back, as they provide the same service anyway.
    Slightly bemused by then, I gave it a shot. The girl I spoke to said that Sky will only carry out 'full installations' (dish+box) and that it is because they are a large company they can offer Sky+ for £99. She couldn't explain why it was that Sky couldn't install just the box and not the dish. She did however suggest that I look in Yellow Pages for a second-hand box if I wanted one cheaper.
    Does anyone have any experience of second-hand boxes? I've just spent a not inconsiderable amount of money on a home cinema system and am aware of various hardward/software upgrades that Sky have implemented recently to Sky+ so don't really want to compromise. Nor do I see why I should, given the situation.
    As a new Sky customer (potentially, though on the evidence so far...) I would appreciate any advice.
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    If your current communal dish already supports Sky+, you should order the service from Sky and pay the discounted price. Then when the bloke with the ladder arrives with the new dish and box, ask him not to go up the ladder and change the dish. He'll be cool about it, I'm sure. Ask him to just install the sky box and test it. He won't tell Sky that you didn't use the new dish and eveyone's happy. Try it.
    But check your communal dish is Sky+ ready first.....
  3. wizbongre
    wizbongre
    Jun 24, 2003
    592
    Liverpool, Merseyside
    +63
    When me and the girlfriend moved into our current house, the people we bought off had normal Sky Digital but not Sky+ - they took the Sky box with them.
    We ordered Sky+ and the guy just left the existing dish and added an extra cable to feed the Sky+. Don't see why this isn't the same as what you are after....
    Just sounds like the usual crap Sky service ;-)
  4. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,870
    2
    In a secret location with Jennifer Lawrence
    +9,740
    All (most) the Sky installers are sub contractors, therefore whatever you ask them to do if it eases their installation, I am sure they will do. They already try and do it in record quick time anyway so if it speeds up their installation, then it's a bonus for them as they can get on to another installation. I think they get paid per installation anyway?
  5. Mr THX
    Mr THX
    Nov 26, 2002
    1,309
    Barnsley
    +32
    Has the £99 deal finished then :confused: I've looked around the $ky site and only find a deal for £149.......... :rolleyes:
  6. Emm
    Emm
    Jan 9, 2004
    Norfolk
    For new subscribers it's still £99
    Look here
  7. Matt V
    Matt V
    Aug 16, 2004
    69
    11
    +5
    Thank you all for your cunning advice. I will give it a try!
    Nobber22 - how do I check if my dish is Sky+ ready? I am presuming that having two points means it is...
  8. AV Junky
    AV Junky
    Oct 30, 2002
    1,214
    Staffordshire, UK
    +69
    Did the same, no problems.
    As long as it is two independent feeds running back to the switching box, then you should be fine. Should only be a problem if they have just used a splitter from one cable feed. They would have to real cowboys though for the latter!
