Ricoh Caplio R5 settings
paulbton
I have a Ricoh Caplio R5 and like to take pics at concerts but at low light its hard to hold the camera still to get a clear picture.
Do I need a new camera or are there settings I can use to help?
SevloW
When it came out in 2006 the R5 was highly rated, however looking at one review it states :-
quote
Ricoh proves once again that it can match and often exceed anything its rivals can produce. The Caplio R5 has a unique specification, combining wide angle and long telephoto abilities, effective image stabilisation and a usable high ISO setting, with good image quality and outstanding performance. Its only weak point is its poor low light focusing ability.
unquote
So whilst it provides excellent results under decent lighting conditions - it would appear af focusing in low light is the main problem.
Looks like you may need to upgrade, if your keen on concert photography
SevloW
The Fuji FinePix F80EXR has good reviews and they suggest that low light performance is good. Amazon have it for around £146, Dixon's for £149.
I have no experience with it though. Maybe others will be able to suggest some models.
