Richer Sounds panny scht27r
Discussion in 'Home Cinema Buying & Building' started by Kid A, Oct 18, 2004.
  1. Kid A
    Kid A
    Mar 20, 2004
    4
    I just saw this system in richer sounds but can't find any details about it on the net at all the panny site are seeling a scht25r but this has a recorder with it and is a different model.. any info on this machine would be VERY much appreciated thanks :)
  2. nogimmix
    nogimmix
    Dec 4, 2003
    2,120
    Kent & Canary Wharf
    +82
    I've noticed the same thing...........if it is the 25R version I'm going to snap it up quickly.
  3. rover
    rover
    Jun 2, 2003
    60
    9
    Norfolk
    +12
    Has anyone identified this yet? Is it the multi-region version of the Panasonic SCHT25R?
  4. nogimmix
    nogimmix
    Dec 4, 2003
    2,120
    Kent & Canary Wharf
    +82
    It's actually a 2 piece system, one being the 5.1 system, while the other is the dvd player.........which isn't DVDR.
    Still a good deal if you are looking for a first 5.1 system.
  5. DD29
    DD29
    Feb 15, 2003
    27
    4
    Is this the system:
    http://ws1.richersounds.com/showproduct.php?cda=showproduct&pid=PANA-SCHT27R
    Has anyone here got it?
    I was originally going to get the Panasonic SCHT520, but after discovering that it won't decode externally connected sound (TV, VCR, Gamecube,) in DPL2 I decided to keep searching for a system that will.
    So does anyone know if the SCHT27R can decode from external sources?
    Cheers.
  6. steve36
    steve36
    Dec 11, 2002
    965
    Warwickshire
    +33
    I also would like to know if it can decode external sources as information on this '27' model is lacking.
    It does look very good value, and if is sounds similar to the '25R' then IMO it should be very good value for money.
    Steve.
  7. nogimmix
    nogimmix
    Dec 4, 2003
    2,120
    Kent & Canary Wharf
    +82
    I have viewed this in RS and audio wise it has 2x optical inputs, 2 x RCA inputs.
    Bloke in RS also told me that it does indeed decode external sources.
