Richer Sounds Deliveries ?????
Discussion in 'Plasma TVs Forum' started by cucuz, Dec 7, 2004.
  1. cucuz
    cucuz
    Jun 16, 2004
    123
    +6
    Just a note of caution to anyone buying a plasma from Richer Sounds . Today I have for the second time in a fortnight seen a delivery of plasmas to to one of their stores ...... 6 PLASMAS LAYED FLAT ON EACH PALLET ! Now call me Mr Picky but this doesn't seem quite right, does it ? :nono:
  2. papachumba
    papachumba
    Oct 4, 2003
    79
    hmmm.. maybe the laying flat (at least before the first use) thing is just a roumor? can anyone confirm for sure?
  3. JonStatt
    JonStatt
    Nov 18, 2004
    3,352
    103
    +445
    There is nothing wrong with it lying flat. It is just that the plasma is strongest in a vertical position. On its belly it won't take much pressure to crack the glass. Therefore to minimise the risk of breakage, it should be transported vertically. I know of no issue referring to first use, or having to wait before switching it on (like a new refrigerator)
  4. bobbypunk
    bobbypunk
    Pioneer worry about it enough to put a sensor on the side of their plasma boxes to make you aware if it has been tilted!!
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,763
    The Borders
    +3,087
    Hello all
    Laying a Plasma flat whilst its being transported in a van or similar is not a smart move.
    Take any large piece of flat glass and bounce it around in a van and it'll flex - now put a load of electronics within a mm or two of the plate of glass and see what happens when the glass 'bottoms' out on the electronics.
    Plasma work fine after they have been laid flat - in fact we've used some in a horizontal orientation on exhibition stands and the like (you do have to provide additional ventilation though).
    Very early c1998 Fujitsi panels suffered some strange effects after they had been transported - especially so if they got very cold; and these panels did require a bit of 'standing' time.
    I've never seen this phenomenon on any other Display since then.
    Best regards
    Joe
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    So the problem is purely physical. IE Richer's problem. They might get 6 broken plasmas out of it, or they might all be fine. It's a very sad sight, they break like a car window, and it all sits in a horrid pile behind the plastic front screen.
  7. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    Good job I acquired a spare screen for my 434!
