Hi, is it possible to get a lead that has the scart for RGBs to fit the sky+ box one end with 3 component terminations the other end - i.e. no separate sync connection? So the sync would be through one of the other 3 connectors.
Galaxy - what I was trying to say unclearly was is it possible to have an RGBs scart to component cable with only 3 terminations with the sync being incorporated in one of the 3 terminations (sorry don't know correct terminology.)
Still RGB but with sync on green? You have to have a scart device that does this. If you just connect a scart to RGB lead, you just get no sync, and incorporating the sync is not just a lead. I think Nokia freeview boxes do this, and one or 2 other things, sync on composite os much more usual. Netgem can be switched from RGB and sync on composite, to YUV, in the menu. You then nned a scart to 3 phono lead, connectrd to the RGB pins to output it. Contact me here or via www.tbpav.co.uk if you want one.
