RGBS cable scart pin No help
Discussion in 'Projectors, Screens & Video Processors' started by minimivic, May 16, 2002.
  1. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Can anyone tell me what the scart pin numbers for RGBS out of a Sky digibox are.
    Is it:
    5 Blue ground
    7 Blue
    9 Green ground
    11 Green
    13 Red ground
    15 Red
    17 Sync ground
    20 Sync input
    If it is, it doesn't work, and this is a cable from a well known cable manufacturer.
    Otherwise if it is correct I cant get RGBs to work on the Sim2 HT300.
  2. Dangerous
    Dangerous
  3. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Thanks Dave,
    I've seen that before. It does explain a few things though.
