RGBHV or VGA
Discussion in 'Cables & Switches' started by Hawklan, Feb 19, 2005.
  1. Hawklan
    Hawklan
    Oct 20, 2001
    6,747
    Essex
    +315
    What will give the best picture from a HCPC to a projector
    VGA to VGA or
    VGA to RGBHV
    Many thanks
    RON
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Ron,
    I know the socket is often referred and named as VGA but it's actually an HD15 to HD15.
    I'd say that if you're using a PJ that has BNC sockets for the RGBHV then an HD15 to 5 BNC would be ideal. If the RGBHV sockets are phono sockets then you might want to stck with HD15 at both ends.
    Gordon
  3. Hawklan
    Hawklan
    Oct 20, 2001
    6,747
    Essex
    +315
    Hi Gordon
    My projector is a JVC DLA G15 Dila projector
    It does have BNC sockets for the RGBHV, as well as YUV (BNC) and HD15
    I just didn't know what would produce a superior picture from a HCPC of the 3 options
    Many thanks
    RON
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    AFAIK VGA (HD15) carries RGBHV. Thus I would think it merely depends on what connection you have at the source and what cable you are going to use ...
  5. Hawklan
    Hawklan
    Oct 20, 2001
    6,747
    Essex
    +315
    Thanks Guys
    I have a cheap reasonable quality HD15 to HD15 coming I might just get a HD15 to RGBHV as well to do a side by side comparison and let you know what I think
    Many thanks
    RON
