Rgb
Discussion in 'General Video Gaming Chat' started by Simon1987, Jan 5, 2007.
  1. Simon1987
    Simon1987
    Sep 15, 2005
    34
    hi guys, i have a ps2 and a gamecube, my tv accepts an RGB input.
    is it that much better than component? also my tv only has 1 rgb input so i'd have to swap the cables around everytime. is there a solution to this? (Short of buying another telly_
  2. t-force
    t-force
    May 2, 2001
    1,872
    Southampton, UK
    +152
    As far as the Cube goes, component will give a marginally better picture than RGB on most TVs; if you've got either an NTSC Cube, or a PAL Cube with Freeloader and NTSC games, then many of the games will be progressive scan compatible, and that will give a significant improvement.
    If you don't already have a component cable for your Cube, then good hunting, as they're very hard to find (never released officially in this country), and you'll need to make sure that your Cube has a digital out socket.
    If you stay with RGB, then the best thing to do is buy a SCART fully wired switching box. Argos used to do a surprisingly good one, and I think that this is its successor.
