Rgb
Discussion in 'Satellite TV, Sky TV & FreeSat' started by crowj999, Oct 4, 2004.
  1. crowj999
    crowj999
    Assuming I get the latest Sky+ Digibox and use the SCART socket in RGB mode to connect with my Sony TV's RGB sokcet will everything work given my TV is NTSC only ?
    I am led to believe RGB is independant of any PAL/NTSC issues.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    A NTSC only telly with a scart socket, never seen one of them, what conutry was a built for?
    I honestly do not know if it would work but regardless of it's capability of accepting RGB via scart the basic spec would indicate that it's still a PAL 50hz input not a NTSC 60hz. A PAL telly made in the last 20 odd years can handle NTSC, it's rare for a NTSC telly to support PAL.
  3. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    Unless it's a multi system one, it won't. You can get it modified by a TV repair shop though. Not sure what cost would be.
