RGB YUV to Scart.
Discussion in 'Cables & Switches' started by ibme_uk, Aug 15, 2005.
  1. ibme_uk
    ibme_uk
    I've got the Acer AL2671W which has two scart sockets, One does RGB and the other does RGB and YUV.
    I want to get a better video lead than the one supplied, the one supplied has a Red, Green, Blue (Which I am using for YUC), Yellow, Red, White (Using red and white for audio).
    What I need to know is am i right in thinking that I can use a RGB (3 Phono) to Scart cable to carry the YUV (as the acer has a YUV scart socket). I will use the digital out into a 5.1 amp therefore no reqirement for the audio.
  2. Jakus
    Jakus
    Aug 5, 2005
    522
    28
    +39
    RGB is different to component, YUV is Digital, It is possible Acer have wired a Scart for YUV but I would think it very Strange !
    Thought I read 1 scart RGB and the other S-Video.
    How do You find the Al2671W ?
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,284
    The Borders
    +2,573
    ibme_uk
    YUV on a SCART socket is unusual but not impossible - there are a few DVD players and the odd Freeview Digibox that output YUV on SCART and a couple of Loewe TV's have YUV Inputs on SCART :)
    Not many cable companies carry the 3RCA to SCART configuration as a stock item so the likes of VanDamme are a good option as they build cables to order.
    Best regards
    Joe
