Quantcast
RGB/YUV switch on Philips 963SA
V
vlza
Cannot find the answer via search, maybe someone could help.
In DVD Philips 963SA it is not possible to have signal on YUV component and RGB scart at the same time, and this is mentioned in manual. It is also stated: "To choose your preferred output connection, refer section “Personal Preferences - YUV/RGB
switching” ".
But there is no such section in manual, no relevant information in other sections and nothing appropriate in system menu of the player! Whenever I have RGB/SCART connected - signal on component disappears, and no way to switch it on back (except for removing SCART)!
Does anybody know - if there is a software RGB/YUV switch?
V
vlza
Well, ok, probably this is my TV (PD30) which prevents itself from being switched to component, when it detects RGB...
Thank you, puddleduck!
