RGB with optical cable
Discussion in 'Cables & Switches' started by Caprylate, Sep 17, 2005.
  1. Caprylate
    Caprylate
    Aug 1, 2005
    84
    +3
    I've been trying to find an RGB scart with an Optical out connection so I can have Surround Sound and the best SD image quality, but so far all my searches lead me to Xbox RGB scarts with Optical out, obviously this is no good to me since I need RGB to RGB with Optical out, so my question is: Where can I get them? Whats the max-min I should be prepared to pay (ideally it would be £20-ish). At the moment, NTL uses a basic scart and 2.1 set-up so 3 of the speakers are left unused.
    All help appreciated,
    Caprylate.
  2. loadsofleads
    loadsofleads
    There is no such cable, Scart only carries audio up to Dolby Pro-Logic quality, For Dolby Digital you will need a seperate optical cable from your STB to your receiver.
  3. Caprylate
    Caprylate
    Aug 1, 2005
    84
    +3
    Thats dissapointing.
    So can you reccomend me just an RGB cable for NTL? Nothing too expensive, but good enough so I can tell the difference between plain scart and RGB. Again somewhere in the price bracket of £15-£25 would be great.
    Thanks,
    Caprylate.
  4. Member 34135
    Member 34135
    An RGB only cable will not give you audio, if that is what you want go for the Ixos XHV601 (note V for RGB only), 75cm and 150cm versions are on offer at the moment.
    If you want sound then go for something fully wired like the Ixos XHT611 or XHT601.
    Andy.
