RGB with NTL problems - please help!
Discussion in 'Cable TV & Virgin Media TV' started by damolong, Jul 4, 2002.
  1. damolong
    damolong
    May 15, 2002
    76
    Hello
    I have just had a new Philips 32" 6006 TV delivered with 2 scarts - 1 RGB.
    I have connected my NTL Pace box upto the RGB scart, and changed the setting in the Pace menu to RGB. Whilst the quality of the picture and menus is a lot better, the screen is very dark. I am reluctant to mess around with the brightness menus - plus then DVDs etc will be far too bright!
    Anyone any ideas?
  2. Squirrel God
    Squirrel God
    I seem to remember reading on these forums that RGB is a bit dark/dull on the 6006. If you do a search, you'll be able to find out if my memory is good or bad :)
